Nighthawk x4s and Netduma R1 together
Elrod
Default. I just reset it again. The auto setup actually worked but my speeds still suck.
Double check these settings:
Preemptive Algorithm
100% anti-flood
Share excess enabled
Reset device prioritisation & apply
Disable IPv6 in WAN, LAN & misc
Disable deep packet processing in misc
Do a wired speed test from a PC (make sure no one is using the internet while running the test)
Something worked. Wireless speeds still suck. I can set beside it and run a wifi test and barely hit 30. Hook up nighthawk and run 40-50 on the other end of the house.
A lot of us use a Nighthawk as an Access Point to take advantage of the better WiFi and still get to use all the features of the Duma.
I decided to purchase a XR500 today. Hope this fixes my issues.
Let us know if you need any help with the XR500
Hopefully you enjoy your XR500 - if you need any assistance you know where to find us :D
