Problem with internet and lag
Hello
My download is 11m and upload 1m , the worst thing that when my family using intrnet I can't even play , I try to make it 70% both of grean line but still the same , I really having enough ,
Device Prioritization is going to be your best friend. I would probably alot 90% to your gaming console.
Hi Ahmed,
A few things:
  1. Make sure the gaming device is connected by wire
  2. Make sure you have "Set Bandwidth" correctly on congestion control. Set that to what you pay for
  3. When you are gaming set the anti-flood bars to 70% each way
  4. On Device Prioritisation give your games console 90% of bandwidth
Doing that should mean that your family do not make you lag.
Does your family use torrents? If so make sure utp is disabled.
