zac115 Posted March 17, 2018 Posted March 17, 2018 I need help setting up the xr500 to be able to support warframe port forwarding. im not sure how to do that as the ui is just a tid bit confusing. here is the site that explains what i need in the port area.
Administrators Netduma Admin Posted March 17, 2018 Administrators Posted March 17, 2018 Hi Zac - it’s best to let UPNP do this automatically for you. If you go to >Settings >Advanced >UPNP then make sure enable UPNP is checked. When you play your game the ports will be opened for you. However, if you really want to do it yourself, you can then add manual rules by clicking Port Forwarding from the advanced options menu
zac115 Posted March 17, 2018 Author Posted March 17, 2018 Hi Zac - it’s best to let UPNP do this automatically for you. If you go to >Settings >Advanced >UPNP then make sure enable UPNP is checked. When you play your game the ports will be opened for you. However, if you really want to do it yourself, you can then add manual rules by clicking Port Forwarding from the advanced options menu but how is my question. a port forwarding page looks like this but the dumaos does not.can you give me a picture of how to do this? and upnp does not have the ports i need so it does not work other wise my game would not be telling me to open them. EDIT: is the internal and external ports just a different way of saying the starting ports and ending ports?
Administrators Netduma Admin Posted March 17, 2018 Administrators Posted March 17, 2018 Choose 'Add custom service' to setup your own rule. This video explains more: https://youtu.be/KQiwtXoNqsA?t=1578
Administrators Netduma Admin Posted March 17, 2018 Administrators Posted March 17, 2018 EDIT: is the internal and external ports just a different way of saying the starting ports and ending ports? No - the starting and ending ports are the range e.g. 2001 - 2999
