Nighthawk Pro Gaming Posted February 6, 2018 Posted February 6, 2018 So I have the XR500, and a gs108 switch. Currently I have the Xbox One and my PC connected to the switch as well as other stuff. Everything is Gigabit. When I stream my Xbox to my PC, I occassionally experience lag. I am thinking there might be a way to isolate these 2 devices from other LAN traffic to increase performance and hopefully eliminate the lag. Is there a way to do this? View the full article
SHANE523 Posted February 7, 2018 Posted February 7, 2018 Currently I have my XR500 only using 1 port for my LAN and a Dell6248 behind it for my devices to connect. I also disabled the Wireless on the XR500 because I already had a very good AC WAP setup. I am debating having my consoles bypass the switch and go directly to the XR500. I am running some other tests to see performance differences but the one game that I have been playing has network issues that, as good as it is, the NetDuma cannot correct.
Administrators Netduma Fraser Posted February 7, 2018 Administrators Posted February 7, 2018 What is the game that you're playing? For some games where the Geo-Filter cannot help you are at the mercy of their matchmaking systems so all you can do is make sure your local connection is minimal as possible with QoS.
