leemoore2011 Posted February 5, 2018 Posted February 5, 2018 Hi Guys, Having some problems with my netduma ... Basically i just have the power light and act flashing when I power it up ... I have tried to reset from the back of the router ( i can't get into the settings to do anything else) No other lights are on at all . I have had the duma since they first came out to be honest so maybe it has just run its life cycle ..
BIG__DOG Posted February 5, 2018 Posted February 5, 2018 unplug it for 5 mins then with a pin or similar press the reset button and keep it held in while you push the power cable back into the R1 and keep the reset button pressed in for a further 10 seconds and then release and see if that works.....make sure you are connected wired via ethernet also. B.D
Netduma Staff Netduma Jack Posted February 6, 2018 Netduma Staff Posted February 6, 2018 Hi Guys, Having some problems with my netduma ... Basically i just have the power light and act flashing when I power it up ... I have tried to reset from the back of the router ( i can't get into the settings to do anything else) No other lights are on at all . I have had the duma since they first came out to be honest so maybe it has just run its life cycle .. Please let us know how you get on with this. I don't think it's necessarily a problem that those lights are on. If you plug an Ethernet cable in different ports, do any port lights switch on? Also, are there any other symptoms or issues? Can you access the interface, and is the WiFi / Internet working properly?
Serban Posted September 12, 2018 Posted September 12, 2018 I am having the same problem!!! Someone help please!!! I plug it in and I hear no beep like i used to and all the lights just flash!!!
Netduma Staff Netduma Jack Posted September 12, 2018 Netduma Staff Posted September 12, 2018 8 hours ago, Serban said: I am having the same problem!!! Someone help please!!! I plug it in and I hear no beep like i used to and all the lights just flash!!! I've replied to your email Serban, we'll investigate it further with you
