hallman0709 Posted January 25, 2018 Posted January 25, 2018 What speed can the Netduma handle? I just received a new router with my internet provider. My new internet is fiber where before I was on DSL. I am paying for 600 mbps up and down with my internet provider but the Netduma speed is only registering at 45 mbps down and 25 mdps up. I am registering 450 mbps down and 500 mdps up at the new router . Is there a setting that I need to adjust on the Netduma to make my mbps go up?
Administrators Netduma Iain Posted January 25, 2018 Administrators Posted January 25, 2018 The netduma r1 can handle wired speeds up to about 800mbits (although some features may have to be turned off like DPP). The Wi-Fi is limited to just under 100mbits because it is not ac. For tuning the r1 for speed please read this: http://support.netduma.com/support/solutions/articles/16000022366-why-is-my-connection-speed-lower- If you have NETGEAR xr500 you can handle all features at 1000mbits. And wireless communication can be even higher. Hope that helps
hallman0709 Posted January 25, 2018 Author Posted January 25, 2018 It help some up to 75 mbps down and 274 mbps up now that running speed test 3 time on the pc run speed test on the ps4 and got 122 mbps down and 85 mbps 3 time to My new router from internet provider is a smart/rg model sr400ac is says it a gigabit router and thank you for helping me
Administrators Netduma Iain Posted January 25, 2018 Administrators Posted January 25, 2018 Hi hallman, if you're wired. You should be able to optimise to reach your max speeds. If you need further help configuring let us know please
