Problems with MLG Gamebattles on CoD:WWII
Hi all,
I've been having a consistent problem recently whereby I am failing to join MLG Gamebattles matches through the integrated system in Call of Duty WWII. The issue is that when I join, it won't put me in the same lobby that my teammates/our opponents are already in. I've noticed under Console Info in Settings in the game that my NAT type has been strict. The only solution thus far has been a complete internet reset by turning off my BT Home Hub for 30secs and turning it back on. This restores a moderate NAT type.
I have no port forwarding rules set up in BT Hub Manager and have UPNP enabled on my R1.
Anyone have any ideas what this problem could be? It's happened multiple times. It may not even be the R1's fault at all, as I tried bypassing it by connecting wirelessly to my Home Hub last night and still the problem persisted.
Thank you for any help you can provide,
Joel
Is your Netduma in the DMZ of the home hub? Please ensure that this is the case. You might need to set up port forwarding on your Netduma as well, perhaps Gamebattles is using a port that hasn't been detected by UPnP.
Yes, my R1 is in the DMZ for my BT Home Hub.
The in-game message around NAT Type says the game tries to use UDP port 3074, which I believe UPnP is automatically forwarding to my PS4's IP address. What other ports would you suggest manually forwarding through the Netduma Interface?
There are these:
Call of Duty - WWII - PC
TCP: 3074,27015-27030,27036-27037
UDP: 3074,4380,27000-27031,27036
Call of Duty - WWII - Xbox One
TCP: 53,80,3074
UDP: 53,88,500,3074,3544,4500
Call of Duty - WWII - Playstation 4
TCP: 80,443,3074,3478-3480
UDP: 3074,3478-3479
But also sounds like you need to disable the Geo-Filter for Gamebattles mode because you are playing against predetermined players.
