major masingil Posted November 6, 2017 Posted November 6, 2017 #Duma Army, Has anyone ever explored using Hyper traffic for prioritizing Skype or Webex conference calls? I assume you would need to set up manual rules in the advanced section. Can I please hear some suggestions and thoughts? I will be receiving land line, cellular, and internet connections to the same conference bridge. I already have a skype phone number, but I'm open to better conference call apps, if there are suggestions. 1 big drawback of skype is I can't record the calls, which is something I want to be able to do.
Administrators Netduma Fraser Posted November 11, 2017 Administrators Posted November 11, 2017 In theory yeah that could totally work. I'm not sure exactly how much bandwidth conference calls would use but as long as it's not too much you should be fine to use Hyper traffic. Find out what ports it uses and then make custom rules. If they're all above 1024 you can use the console service.
major masingil Posted November 14, 2017 Author Posted November 14, 2017 Thanks Fraser. As a follow up question. when setting up the advanced rules I have an option to select "Destination Only," "Source Only," or "Both" can you let me know which of those I'm supposed to go with?
major masingil Posted November 14, 2017 Author Posted November 14, 2017 In theory yeah that could totally work. I'm not sure exactly how much bandwidth conference calls would use but as long as it's not too much you should be fine to use Hyper traffic. Find out what ports it uses and then make custom rules. If they're all above 1024 you can use the console service. Hi Fraser Can you see my post above this reply please?
Administrators Netduma Fraser Posted November 14, 2017 Administrators Posted November 14, 2017 I would just choose both to be safe
major masingil Posted November 14, 2017 Author Posted November 14, 2017 I would just choose both to be safe Thanks Fraser. All the best
