thewilloxdiaz Posted October 27, 2017 Posted October 27, 2017 So, recently i got Destiny 2 on PC as a gift, honestly i wasnt looking forward this version, and i just tested the PVP and is garbage, just like the console version. Yes, it runs very smooth, the 60 fps looks very well and aiming with the mouse is very much accurate (using aim assist with a controller will get you a lot of recoil) but the PVP multiplayer is still bad, im always getting melted in the most of the gun fights, im always getting into lobbies with people from the U.S. and im from South America and yes, im getting booted with beaver code on PC too. Im using Chive's config but does anyone have any suggestion to improve the PVP?
Born Highlander Posted October 27, 2017 Posted October 27, 2017 TBH i think its all about the weapons you use in Destiny. I am no FPS god but have used Urials Gift, Origins Story and Nameless Midnight throughout and have had some fair results with them. A lot of ppl like the Midas, but i cant get on with it and you see it to much in PvP.
Administrators Netduma Fraser Posted October 28, 2017 Administrators Posted October 28, 2017 Are you using the very latest cloud numbers that are available? I made it much more efficient.
thewilloxdiaz Posted October 28, 2017 Author Posted October 28, 2017 Are you using the very latest cloud numbers that are available? I made it much more efficient. Yes, im using it on PC and PS4. Same on booth sistems.
Administrators Netduma Fraser Posted October 29, 2017 Administrators Posted October 29, 2017 Can you keep providing ID's if possible when being booted please. If we can eliminate that properly then we may be able to get you better games
thewilloxdiaz Posted October 29, 2017 Author Posted October 29, 2017 Can you keep providing ID's if possible when being booted please. If we can eliminate that properly then we may be able to get you better games Sure. I will.
