Deviousfive Posted September 9, 2017 Posted September 9, 2017 Hi i e only had my netduma r1 for a couple of days and I think it's great however my bat setting switched from open to moderate I tried using the res button to see if it would change back. The nat problem has been solved however the router is now acting up geo filter seems to turn on and off I get kicked out of games if I restart the router I find settings enabled that weren't before the restart. Can u please help !!! Perhaps remotely reinstalling the os? Thanks
ColonicBoom Posted September 10, 2017 Posted September 10, 2017 Hi i e only had my netduma r1 for a couple of days and I think it's great however my bat setting switched from open to moderate I tried using the res button to see if it would change back. The nat problem has been solved however the router is now acting up geo filter seems to turn on and off I get kicked out of games if I restart the router I find settings enabled that weren't before the restart. Can u please help !!! Perhaps remotely reinstalling the os? Thanks Enable cookies in miscellaneous settings. Set the settings you want. Reboot the Netduma from miscellaneous settings. You should read the wiki guides. If you've read them already you need to read them again.
Deviousfive Posted September 10, 2017 Author Posted September 10, 2017 Done that and read them hasn't made a difference
Netduma Staff Netduma Jack Posted September 10, 2017 Netduma Staff Posted September 10, 2017 Done that and read them hasn't made a difference Hi, welcome to the forum! If you have enable cookies ticked and are restarting the router via Settings > Miscellaneous, then you shouldn't in theory be losing your settings. Which firmware version are you on? Are you using Google Chrome or Firefox? Try configuring your settings using a different device on Google Chrome and restarting the router, and see if the settings save.
Deviousfive Posted September 10, 2017 Author Posted September 10, 2017 Had to reinstall os it's sorted now thanks guys
Netduma Staff Netduma Jack Posted September 11, 2017 Netduma Staff Posted September 11, 2017 Had to reinstall os it's sorted now thanks guys Oh, good to hear! We usually wouldn't recommend doing that since it can be risky, but I'm glad it fixed your issue. I'm going to lock this thread, but if you have any more questions please feel free to open another thread
