I need help with buffer bloat in my download.
I need help badly, my download buffer boat is out of control.  on dsl reports I get +600 non stop. I even put my congestion control to 10% and it helps a bit, but my buffer bloat in the download section of the test is still in the red. I have 100 mbps, and when I do the test I have to put it all the way down to 10mbps just for it not be as bad. is there any settings on the netduma that will fix  my problem?
Hey, welcome to the forum! Try out these settings:
- Type the speeds you receive from a wired speed test into Set Bandwidth
- Reactive Algorithm
- 70% anti-flood
- Share excess enabled
- Reset device prioritisation & apply
- Disable IPv6 in WAN, LAN & misc (Unless you know that you are on IPv6)
- Disable deep packet in misc
- Ensure the ethernet cables you're using connecting the R1 to hub & R1 to PC are Cat5e+/can handle your speeds.
- Do a wired speed test from a PC
Make sure all devices are connected to the Netduma, and that your Ethernet cables are functioning properly. If you have Anti-flood below 100%, it tends to eliminate buffer-bloat since it gives enough 'head-room' to prevent it. Make sure when you run your tests you do it wired to a PC. Let us know how you get on :)
