Ktrachok1ll3r Posted July 6, 2017 Posted July 6, 2017 I'm new with netduma I just buy it yesterday and I been receiving a error marionberry and I can't play never happen with my apple router need help plz I'm on Xbox one
Chive972 Posted July 6, 2017 Posted July 6, 2017 I'm new with netduma I just buy it yesterday and I been receiving a error marionberry and I can't play never happen with my apple router need help plz I'm on Xbox one Hi guardian, take a look here: http://forum.netduma.com/topic/20726-the-best-settings-imo-for-the-10306-firmware/ Also, put those values on cloud settings with options unticked: 35,31,28.
Netduma Staff Netduma Jack Posted July 6, 2017 Netduma Staff Posted July 6, 2017 I'm new with netduma I just buy it yesterday and I been receiving a error marionberry and I can't play never happen with my apple router need help plz I'm on Xbox one Hi, welcome to the forum! The suggestion above is great - you need to put those numbers in the cloud section in Settings > Misc. All they do is use a different cloud version, which controls which servers are automatically blocked / allowed on the Geo-filter and other Geo-filter stuff. Also make sure you have strict mode disabled on the Geo-filter let us know how you get on!
Ktrachok1ll3r Posted July 6, 2017 Author Posted July 6, 2017 thanks for reply I'm on Xbox one I have the Netduma router version 1.03.6h I have some problem is the error marionberry and the NAT is moderate and in the details your network is behind a port-restricted NAT and I forgot I have 3 xbox one
Netduma Staff Netduma Jack Posted July 6, 2017 Netduma Staff Posted July 6, 2017 thanks for reply I'm on Xbox one I have the Netduma router version 1.03.6h I have some problem is the error marionberry and the NAT is moderate and in the details your network is behind a port-restricted NAT and I forgot I have 3 xbox one Is that in-game NAT or your Xbox NAT? Try this guide for your NAT: http://support.netduma.com/en/support/solutions/articles/16000022359-how-do-i-open-my-nat- Do you see any blocked / padlock servers on the Geo-filter map when you get this error message? If so, please click on that server and post its ID here.
Ktrachok1ll3r Posted July 6, 2017 Author Posted July 6, 2017 Thanks I'm doing the configuration chive972 I'm on the step 9 once I finish and going to number 10 it don't let me it's said error loading misc page. Please post issue at forum.netduma and cloud settings is like loading
Ktrachok1ll3r Posted July 6, 2017 Author Posted July 6, 2017 Hello Netduma Jack still the same with NAT Type: Moderate and two of them are Moderate and one is open I have like 6 now blockeds the most close is id 8b185823b52a6469
Ktrachok1ll3r Posted July 6, 2017 Author Posted July 6, 2017 Great NAT Type is Open now with Marionberry still the same I can't play
XSXS Posted July 7, 2017 Posted July 7, 2017 I've been having to disable the geo filter while playing destiny ever since Fraser updated the cloud settings I've been getting kicked. Not sure if coincidence or not. There was another thread about Destiny connection problems where users were giving Fraser server ID numbers to update the cloud to help with this but IMHO made it worse for me. Not sure if because those users were in the Europe and I am in the US??? Any way good luck!
