ImSoCakes Posted June 2, 2017 Posted June 2, 2017 just got everything plugged in and setup for my router, i usually get about 350 download and 20 upload through ethernet, but when i go on my pc now and run speedtest i literally get uner 1 download and 15 upload? whats the issue?
ImSoCakes Posted June 2, 2017 Author Posted June 2, 2017 Be wonderful if i can actually speak to somebody that has one and can walk me through the mess
brutus209 Posted June 2, 2017 Posted June 2, 2017 I have had my same settings for over a year so I'm a bit rusty, but I may be able to help. Did you input your up and down speeds, try and use your actual speeds and not what your ISP says you should have. Maybe run a speed test from your ISP router with the duma disconnected. Re connect your duma, and enter in the speeds you just got. Make sure sliders are at 100% make sure and tick reactive or preemptive based on your true speeds. Run a speed test and see what you get.
PharmDawgg Posted June 2, 2017 Posted June 2, 2017 This link concerns internet speeds and may assist as well. http://support.netduma.com/support/solutions/articles/16000023979-optimal-settings-guide - If less than 50mbps, Pre-emptive Algorithm. If more, Reactive Algorithm - 100% anti-flood - Share excess enabled - Reset device prioritisation & apply - Disable IPv6 in WAN, LAN & misc (Unless you know that you are on IPv6) - Disable deep packet in misc - Enable turbo mode if over 120mbps - Enable super turbo mode if over 300mbps - Ensure the ethernet cables you're using connecting the R1 to hub & R1 to PC are Cat5e+/can handle your speeds. - Do a wired speed test from a PC
ImSoCakes Posted June 2, 2017 Author Posted June 2, 2017 I have had my same settings for over a year so I'm a bit rusty, but I may be able to help. Did you input your up and down speeds, try and use your actual speeds and not what your ISP says you should have. Maybe run a speed test from your ISP router with the duma disconnected. Re connect your duma, and enter in the speeds you just got. Make sure sliders are at 100% make sure and tick reactive or preemptive based on your true speeds. Run a speed test and see what you get. yeah the speeds are really really bad, just ran speedtest and im only getting 1 download and about 20 upload, maybe i dont have stuff plugged in right but im pretty sure i do
brutus209 Posted June 2, 2017 Posted June 2, 2017 Can you run a speed test with the duma out of the mix? (wired to your PC from your ISP router/Modem)
ImSoCakes Posted June 2, 2017 Author Posted June 2, 2017 Ok, i think i have it figured out but i still have the same ip address that i have had on my other router but the other router im not able to chnage the ip address on it, im wanting to setup my vpn but i cannot yet unless i get my ip changed
brutus209 Posted June 2, 2017 Posted June 2, 2017 I hope you get it all sorted out, If not the people on the forum will make sure you get up and running. I had a few issues when I first purchased my duma and got it all figured out with the help of this forum, and has been fine since. Now if someone could make a COD game that isn't a complete piece of shit I would be golden!
ImSoCakes Posted June 2, 2017 Author Posted June 2, 2017 I hope you get it all sorted out, If not the people on the forum will make sure you get up and running. I had a few issues when I first purchased my duma and got it all figured out with the help of this forum, and has been fine since. Now if someone could make a COD game that isn't a complete piece of shit I would be golden! do you happen to have discord by any chance, im still having some issues, I can get stuuf explained better and faster if we can I can actuallly talk to someone
Cutiepie1021 Posted June 2, 2017 Posted June 2, 2017 Hi I'm having issues with my netduma as well, my bandwidth is not saving and I cannot run my ping test need help please!!!
XSXS Posted June 2, 2017 Posted June 2, 2017 Ok, i think i have it figured out but i still have the same ip address that i have had on my other router but the other router im not able to chnage the ip address on it, im wanting to setup my vpn but i cannot yet unless i get my ip changed Enable mac id in wan settings, changed the last two digits of your netduma mac id to something else like C1, D4 what ever really. Click apply, reset modem and then reset Netduma. You should get a new ip address and you can do this as many times as you want to get a new IP
brutus209 Posted June 2, 2017 Posted June 2, 2017 Hi I'm having issues with my netduma as well, my bandwidth is not saving and I cannot run my ping test need help please!!! Make sure cookies are enabled, and sometimes for settings to take I have had to do a reboot from the Duma interface. You may have to reboot multiple times.
ImSoCakes Posted June 2, 2017 Author Posted June 2, 2017 Enable mac id in wan settings, changed the last two digits of your netduma mac id to something else like C1, D4 what ever really. Click apply, reset modem and then reset Netduma. You should get a new ip address and you can do this as many times as you want to get a new IP possibly have a discord or something to run me through this, im really new to all this so im pretty a potato right now that does not know what its doing and i do not want to fuck shit up
brutus209 Posted June 2, 2017 Posted June 2, 2017 possibly have a discord or something to run me through this, im really new to all this so im pretty a potato right now that does not know what its doing and i do not want to fuck shit up Have you been able to get your Duma in your ISP routers DMZ?
ImSoCakes Posted June 2, 2017 Author Posted June 2, 2017 Have you been able to get your Duma in your ISP routers DMZ? what is that lol
brutus209 Posted June 2, 2017 Posted June 2, 2017 what is that lol Basically you need to bridge your ISP router, look up on youtube on how to bridge your model of router. You are going to make it so your ISP router gives up all control to your Netduma.
Administrators Netduma Fraser Posted June 3, 2017 Administrators Posted June 3, 2017 Hey, welcome to the forum! Firstly did you follow Pharms suggestions as that will sort your speeds out. Are you talking about your public IP? If so if your ISP has you on a dynamic IP then you should be able to reboot their modem/router and get a new one. If you're on static you'd have to ring them.
