VIPER51 Posted May 30, 2017 Posted May 30, 2017 Did my port forwarding of Call of Duty. Disabled UpnP. Still strict connection. What could be the trouble?
Administrators Netduma Fraser Posted May 30, 2017 Administrators Posted May 30, 2017 What is the relation to WiFi? Do you have your upstream modem/router in modem mode or the R1 in it's DMZ? If DMZ make sure to disable it's UPnP & port forwarding as well. Have you set a static IP for your console in DHCP lease on the Duma?
VIPER51 Posted May 30, 2017 Author Posted May 30, 2017 Should the DHCP be reserved and checked for the wireless IP number? What should the host number be? All good on the DMZ.
Administrators Netduma Fraser Posted May 30, 2017 Administrators Posted May 30, 2017 Should the DHCP be reserved and checked for the wireless IP number? What should the host number be? All good on the DMZ. Yes tick the reserved box for your console. Host number can be anything between 100-250 I'd recommend putting it as the existing number that your console is so that you don't have to redo port forwarding. What do you mean by wireless IP number?
VIPER51 Posted May 30, 2017 Author Posted May 30, 2017 Never mind on the IP. Where do I find the host number? Thanks Fraser
PharmDawgg Posted May 30, 2017 Posted May 30, 2017 It should be the last digits of your devices IP address. 192.168.88.234 (Host number would be 234).
