Daily Resets need help!!
So i just purchased a Netduma in March. My issue is all my wifi devices work fine then suddenly all get the not connected to the internet issue.
My wired devices do not have any issues with the internet while this is going on. I have to unplug the router and let it reset then all the wifi devices can reconnect. i havent really messed with the default settings other than makin sure its on PSK2, im on the least congested channel in my area, and the workaround option is unticked. If anyone has had similar issues and or if anyone has any info that could help me it would be much appreciated.
thanks
J
Make sure there are no wireless devices near the router such as wireless headphones, phones etc. Anything that produces a signal, especially keep it away from a microwave!
ok there are no wireless devices near it when its having issues. ill be at work and basically all the electronic devices in my room  will be off other than the router. is there any other ideas i can try?
