maazsk97 Posted April 16, 2017 Posted April 16, 2017 On www.ip-tracker.org when you look up an IP address, what does IP address speed means? I have fiber but it shows that my IP address connection has Mobile/Cellular Internet Speed. Does this affect my connection in any way? I previously had a DSL connection and it used to show Broadband (Cable/DSL) Internet Speed all the time.
PharmDawgg Posted April 16, 2017 Posted April 16, 2017 I think it is just limited in its classifications. Alot of Mobile/Cellular networks use a fiber optic structure. If you are currently getting you speeds based on a speedtest to a particular server (hardwired of course) you should not have any issues.
Administrators Netduma Fraser Posted April 17, 2017 Administrators Posted April 17, 2017 Not used the website but I would suggest Buck is correct in this case
