TrayDay Posted April 11, 2017 Posted April 11, 2017 On the fourth port on the router. I always seem to get lan cablend not connected. I've noticed this happened on both my ps4 and ps4 pro when I use the last port on the router with a Cat6 cable. I've even tester to see if it was just the ps4 so, I connected a second router on to that lan port. And the problem persists. It also happens with cat5 as well but not as frequent on that port. I be plaging with multiple consoles at the same time and the other ports and consoles don't get disconnected. They're fine with no issues. I thought it was just the cat6 I had purchased, so I bought a new one and the problem still comtinues. But other than that everything is fine on other ports. Setup is TP-Link 7610 > Netduma all cat6 cables. Miscellaneous enable cookies & enable turbo is only ticked. Three ps4s connected and desktop, with netduma wifi enable (not enabled wifi workaround not to be confused). Mainly using Netduma for everything no AP. Edit: just wiggled the mess out of my lan port on my ps4 pro was Hella scared but so far no disconnect. But will see how well it does in a 72 hour span. Will Keep updated.
Administrators Netduma Fraser Posted April 11, 2017 Administrators Posted April 11, 2017 Okay do keep us updated!
TrayDay Posted April 14, 2017 Author Posted April 14, 2017 Okay do keep us updated! Everything is fine, seem that did the trick. Just wiring wasn't secured. As I was gentle with plugging it in, from hearing horror story of others Ethernet port on their ps4's going out or not working for them. But all good, Fraser!
Administrators Netduma Fraser Posted April 15, 2017 Administrators Posted April 15, 2017 Great as your issue has been resolved I'll close this thread. Feel free to open another if needed
