bay_2002 Posted March 17, 2017 Posted March 17, 2017 I am from Germany and having my internet provided by Vodafone Kabel Deutschland with the CH7466CE Modem/Router combination. I bought a used netduma R1 and resetet it via the reset button on the back side of the netduma. Then I connected the netduma to the CH7466CE via Port 2 and connected all devices to the netduma. Everything works, I am online right now with this setup, but I can´t acces the netduma menue. I read a lot of topics regarding this but can´t figure out what the problem is. The pages for "192.168.88.1", https://r1/"and http://r1/" don´t open. UPnP is activated. Screenshot from the ipconfig attached. Any suggestions what I can do.
Netduma Staff Netduma Jack Posted March 19, 2017 Netduma Staff Posted March 19, 2017 Hey, welcome to the forum. Your IP Config is showing that your IPv4 address is different to "192.168.88.1". That's why you can't access the Interface. Connect the Netduma to a PC via Ethernet, and put your Modem / Router into Modem Mode. Can you access the interface now?
bay_2002 Posted March 21, 2017 Author Posted March 21, 2017 Hello Jack, thanks for the reply. Right now, the CH7466CE is connected to "the wall" and receiving the internet signal vie the german cable network. Attached to this is the netduma where all end devices are connected to. To change the CH7466CE in "Modem mode" you need to call the provider, as far as i know you can´t do it on your own and also I want to avoid this step. I read on your Homepage that it works with every Router and therefore it should work in my constalation too. How can I Setup the cable router (not Modem mode) or the netduma that I can acces the netduma? Thank you in advance.
Netduma Staff Netduma Jack Posted March 21, 2017 Netduma Staff Posted March 21, 2017 When you search for WiFi, do you see "Netduma R1"? If not, do you see any other SSID's that are new? (For example, Mikrotik?)
bay_2002 Posted March 21, 2017 Author Posted March 21, 2017 Hello Jack, yes, the netduma R1 Wifi is there and also could conect to it. I am online with the above mentioned setup too, so in general the netduma works, i just can´t acces the menue with the browser. Chrome by the way.
Netduma Staff Netduma Jack Posted March 22, 2017 Netduma Staff Posted March 22, 2017 Could you try this guide: http://support.netduma.com/support/solutions/articles/16000022375-i-unticked-preserve-settings-when-upgrading-can-t-access-my-router-help That will isolate the router to see if you can access the interface.
Administrators Netduma Fraser Posted March 30, 2017 Administrators Posted March 30, 2017 Hey, welcome to the forum! Were you able to access the interface using the above guide?
