L880NN Posted March 17, 2017 Posted March 17, 2017 Hi All, I have had BT around as I have been complaining about the speeds, they have fixed the line, running wireless and wired speed tests from both the BT HUB and the Netduma router. These are the speeds compared: NETDUMA WIRED BT HUB WIRED There is a significant difference between the two, can anyone help me configure the settings, so that I am getting the same speeds on my laptop and xbox? Many thanks, L880NN
bagsta69 Posted March 17, 2017 Posted March 17, 2017 Are you using reactive settings? Try having a look through this http://support.netduma.com/support/solutions/articles/16000022366-why-is-my-connection-speed-lower-
Administrators Netduma Fraser Posted March 17, 2017 Administrators Posted March 17, 2017 Do the following: Reactive Algorithm 100% anti-flood Share excess enabled Reset device prioritisation & apply Disable IPv6 in WAN, LAN & misc Disable deep packet in misc Ensure the ethernet cables you're using connecting the R1 to hub & R1 to PC are Cat5e+/can handle your speeds. Do a wired speed test from a PC
L880NN Posted March 17, 2017 Author Posted March 17, 2017 New speed on wired Netduma: Again, really appreciate the support. Thanks guys.
PharmDawgg Posted March 17, 2017 Posted March 17, 2017 Great to hear your issue has been resolved. All of the admins, mods and fellow duma army members are here to help. If you have any other questions please do not hesitate to post.
