Can't connect with lan cable
gustins32
Hello,guys i am new on all this,
Everthing was working perfectly till this moment,
so i my netduma  dosen,t  pick up when i plug in lan cable, but wi fi works whats could be wrong ?
I did check everthing starting from faulty internet cable and etc.
what are you trying to connect via lan cable, pc? if so then make sure lan is not disabled in network settings. plug lan cable in while pc is off and restart pc. Also how is your network configured? is everything going through the netduma?
Are you able to access the interface when you connect directly to ethernet? Do you see the light appear on the top of the router when you plug a device in?
Sorry i did meen,i conecting ps4,
and going to netdumar1 control panel,i can,t se my ps4 on it,
did try test network conections bit ween ps4 and netduma it,s showing no lan cable conected,
And on netduma router i just see one flashing light on it,(previocly it was two)
But if i try connect ps4 to netduma  via wifi, everthing works perfectly only speed is ru..... and unplayabl and ps4 uppers in control panel.
I ddi check network cable and it is fine,did run tru tester.
Is any chance,rj45 sockets get faulty (i hope not)
Have you got another ethernet cable that you're able to test with? If so try it in all the ports and see if you receive internet (port 1 of the Netduma should always stay connected to the ISP hub - switch out this cable if you have another to test with as well)
ok i will gone try  ;)
