banjo22 Posted March 8, 2017 Posted March 8, 2017 Hi, I posted this a while back and I was hoping this issue would have been covered in the new firmware by now but unfortunately not: http://forum.netduma.com/topic/18858-network-monitor-suggestion/ Can someone tell me how I'm supposed to work out what device is currently using this much bandwidth (see attached)? There is no black colour in the list of devices and I have around 40 in there anyway! Hovering over it doesn't display the device name, it's a pretty simple situation, the netduma knows what its using it but how I can tell? Surely hovering over the graph it should tell me the device name? Thanks
Administrators Netduma Fraser Posted March 9, 2017 Administrators Posted March 9, 2017 The only way you'd be able to tell currently is unchecking devices at the top or maybe as you have so many the best option is to click the graph so the pie chart pops up, then select each device to see which ones are actually using the internet but you won't get any more info than that. DumaOS will be much better is regards to network monitoring.
