Adding a static IP for PS4 and port forward (disabling UPNP as well)
Hey guys, can you please provide instructions on:
Thanks!
To set a static IP for your PS4 take a look at the device manager for it's current IP then go to DHCP lease, click reserve and then enter the ending of it's IP and apply.
Take a look at this for port forwarding: http://support.netduma.com/support/solutions/articles/16000028196-port-forwarding-settings
If you're manually port forwarding disable UPnP and disable UPnP forwarding in miscellaneous settings. If you have a blue box on the device manager enter the WAN IP into your ISP router's DMZ.
  • 3 weeks later...
