Notification problem
Zennon
Is anyone else having this issue?
It just spins and never resolves. I get this trying multiple browsers.
Note: I have noticed this since the lastest flash update, if that has any correlation.
Yes, I was getting that. I thought it was my browser because I've been using a very old Mac. But if your getting it as well then it isn't just me :)
Cheers crossy, good to know it is not just me then.
You say getting that , do you mean it now works for you mate ?
Yeah. When did that flash update come out? I seen on the IPB website that there is a forum upgrade fixing some new bugs (which was release on Thursday) so maybe if that was release after the flash update it could include a bug fix.
But for now, if it doesn't load I just go to Profile >> Edit Profile then at the bottom there is a tab that says 'My Notifications' and you can view them in there :)
Flash update must be in the last week yes , i check regulary for updates and i noticed the update on thursday and have been seeing this issue since then.
I have a website I upload mixes to, and since the flash update the upload never completes, so ive got two broken things from this , gerrrr lol.
Just tried and its now fixed with no intervention from this side , site update ? :)
No, forum has not been updated.
Its very strange how we both noticed this at around the same time though. This happened so much to me yesterday but has only happened once today and been fine the rest of the time.
Hopefully it stays working :)
Yeah it's strange then :wacko: , hope it stays this way, ocd with broken things tends to kick in haha
It happened to me as well glad it fixed itself
I am wondering if it is a matter of how many is stored, I have deleted all my old ones to see how it goes.
this forum seems to fix itself when it has issues. I really don't know jack about it tbh.
