Need help please
Im having issues wit my R1, I have a recently upgraded my internet service to a 1,000MB download and 100MB upload, every time i go to update the bandwidth, it keeps going back to 100/10.
I play Destiny on ps4 pro and I keep getting kicked to orbit when doing trials of osiris (PVP)  is this the cause?    I was told port forwarding will help in the past?
any help will be greatly appreciated..
Thank you
You should only have to put the bandwidth in once.
Do you keep unplugging it?
Set the bandwidth, go to 'miscellaneous settings', enable 'cookies', reboot from there with the 'reboot router' button.
Then the bandwidth should stay set.
Are you saying it simply won't allow you to put in that value? If you scroll to the bottom of any page on the R1 what version does it say you're on?
Type in 999 & 100, does it accept it then?
For Destiny ensure you're using strict mode off, ping assist 0 and using the manual cloud numbers 30, 28 & 28. Let us know if that resolves your booting issue.
