Fsking Posted December 26, 2016 Posted December 26, 2016 Hello there I have a question I been seeing people do that forwarded these Port 88 (UDP) Port 3074 (TCP) Port 53 (UDP and TCP) Port 80 (TCP) Port 500 (UDP) Port 3544 (UDP) Port 4500 (UDP) Except 3074 (UDP) So do you need to do something like that dose it help get better speed at gaming or ?? Cuz am so confused the only think I did is forwarding my Xbox witch is start 3075 and end 3076 and I have open net.
ColonicBoom Posted December 26, 2016 Posted December 26, 2016 They are just the ports you would manually forward for Xbox One, to avoid NAT issues. If you have an open NAT already then you don't need to worry about them at all. It doesn't affect your speeds or ping.
Administrators Netduma Fraser Posted December 26, 2016 Administrators Posted December 26, 2016 As your question has been answered I'll close the thread. Feel free to open another if needed.
