Lose of speeds after power outage
Hello,
I will start by saying this is not the first time this has happened. I get frequent power surges as of late which causes a momentary loss of power and thus a restart of the routers in my home. I posted on twitter the last time this happened and i thought it was resolved with an update to my browser. Here we are another outage and my upload speeds are back under 200kbs from the usual 85mbs. I followed the optimization post and none of my settings were changed however the speeds are still low. Fraser recommended a browser update the last time and there currently isn't one available.
This is extremely annoying
The firmware is the latest version
normal speeds are 80/80
The following is done
Just double check everything from this list:
  • Reactive Algorithm
  • 100% anti-flood
  • Share excess enabled
  • Disable deep packet in misc
  • Enable turbo mode
current wired speed test is 88.43mbps down and 0.37 up.
Please look into this.
When I used to get power outages (this is before I bought a Netduma router), I also suffered from some internet speed loss. I found that I had to unplug/re-plug both my modem and wireless router to get back to full internet speed.
Have you got a surge protector you would be able to plug the Netduma into?
Try the above suggestion from omega and let us know if that resolves your issue.
If everything is set up correctly on the Netduma then you need to run a speed test direct from the modem / isp hub.
If that is slow then you know it's nothing to do with your Netduma.
If that's normal then you need to post up all of your settings so that we can see what's what.
Also, have a word with whoever supplies your power / wired your house.
