boxone Posted November 16, 2016 Posted November 16, 2016 I've been battling this issue for a while. I'm able to connect to my works Cisco VPN but wasn't able to access servers, etc (can't ping them). I found that unchecking Turbo Mode fixes this issue. Not sure why but I does fix this issue. I just turn it back on after I'm done with work. Basically this is just a FYI if anyone runs into this...
Administrators Netduma Fraser Posted November 17, 2016 Administrators Posted November 17, 2016 Yes I remember this issue, thanks for the reminder! This will be something that should hopefully be fixed in DumaOS but if not definitely picked up in testing.
eddedre Posted November 26, 2016 Posted November 26, 2016 Holy crap! THANK YOU for this post. I had the same issue with my Work VPN as well. I unchecked Turbo Mode and ka boom! it is working now.
Administrators Netduma Fraser Posted November 27, 2016 Administrators Posted November 27, 2016 Will test this to make sure it doesn't occur in DumaOS.
boxone Posted December 9, 2016 Author Posted December 9, 2016 Will test this to make sure it doesn't occur in DumaOS. BTW, the trade off I noticed when turning Turbo Mode off is bandwidth is cut in half but I just turn it back on when done with VPN.
Administrators Netduma Fraser Posted December 10, 2016 Administrators Posted December 10, 2016 Yep if you have over 120mbps then turning off turbo will cut the speeds. I've noted this error so will make sure to get it looked at/test for it in DumaOS.
