Netduma cuts speed in half?
Before using netduma, and by hardwiring my modem into my pc. My speed are ususally 90 down/12 up. Netduma has cut those speeds down to anywhere from 25-50 down/ 4-8 up. I have tried disabling ipv6 as the forum suggests and other that the slow internet FAQ post suggested to no avail. Help?
Do the following:
  • Enter your speeds into bandwidth settings
  • Reactive Algorithm
  • 100% anti-flood
  • Share excess enabled
  • Disable deep packet in misc
  • Enable turbo mode (only if you still can't achieve full speeds after doing everything else)
That seemed to help some but the speed still isnt quite there. And when I try to stream every bitrate is awful, constant buffering. I think I should just return it how do I do that?
Post in the 1 on 1 section and I can take a quick look at your settings. One thing though, make sure you're not putting your streaming PC through the hyper traffic as that may cause issues like this - it is only meant for low latency traffic
Through the hyper traffic? Could you show me where that is?
If you have nothing in there that is fine. Just a thought that could be an issue.
Can put your console in there yes if you're not streaming from it/downloading a lot etc.
In the screenshots in your 1 on 1 thread you have deep packet processing ticked, that needs to be unticked. Should have full speeds after that if you followed everything else i mentioned above
