Pwhirl101 Posted August 21, 2016 Posted August 21, 2016 Everytime i get on netduma my geo filter settings are changed its putting my location in the middle of the ocean with filter distance at 111.00km and ping assist at 50.00ms. When my settings should be in nj with ping assist at 20.00ms. Is this affecting anything with duma or bo3? Aslo im trying dslreports.com its saying geo location failed and not giving me blufferboat score. What should i do please help im new to this. Thanks
Slipknot31286sic6 Posted August 21, 2016 Posted August 21, 2016 Must enable cookies. Use chrome browser. Works the best. Sometimes Firefox glitches I noticed. Set home location. Ping assist Zero, miles 300, max 500. Unplug router for 2 to 5 mins. Plug back in should work perfectly.
Pwhirl101 Posted August 21, 2016 Author Posted August 21, 2016 Ok ive done that but why is my geo filter failed in dslreports.com? Aslo in i set my ping to zero like u said but in bo3 games my oing is all over the place jumping from 15 to 50 constantly game starts lagging
Slipknot31286sic6 Posted August 21, 2016 Posted August 21, 2016 Ping assist to zero keeps u in dedicated server area ur ping will fluctuate rarely over 40. If u don't like server you can tell ban it. Which server you trying to play in?
Pwhirl101 Posted August 21, 2016 Author Posted August 21, 2016 I dont no what server im trying to play in. Im new to this dont know how i would be able to tell thst sorry
Slipknot31286sic6 Posted August 21, 2016 Posted August 21, 2016 To see the Servers. Turn off strict. When you open bo3 and it's downloading settings you'll see a bunch of red circles, these are servers. Chicago, Seattle, Atlanta, southern Illinois, etc. Pick one closer to you preferably.
Netduma Staff Netduma Crossy Posted August 21, 2016 Netduma Staff Posted August 21, 2016 Everytime i get on netduma my geo filter settings are changed its putting my location in the middle of the ocean with filter distance at 111.00km and ping assist at 50.00ms. When my settings should be in nj with ping assist at 20.00ms. Is this affecting anything with duma or bo3? This sounds like you've applied the 'Cod Ultimate' profile - that profile moves your home location into the ocean.
KayOneX-24 Posted August 21, 2016 Posted August 21, 2016 Everytime i get on netduma my geo filter settings are changed its putting my location in the middle of the ocean with filter distance at 111.00km and ping assist at 50.00ms. When my settings should be in nj with ping assist at 20.00ms. Is this affecting anything with duma or bo3? Aslo im trying dslreports.com its saying geo location failed and not giving me blufferboat score. What should i do please help im new to this. Thanks @Geofilter: Have you made a Reboot Router click in the Miscellaneous Settings after you have set up your geofilter to save your settings for permanent ? The router saves your data if you make a reboot manually. @DSLReports: It's a bug in the service itself. I also get the geo location failed error message since 1 week. Nevermind. It works anyway.
Pwhirl101 Posted August 21, 2016 Author Posted August 21, 2016 This sounds like you've applied the 'Cod Ultimate' profile - that profile moves your home location into the ocean. Yes im using cod ultimate
Pwhirl101 Posted August 21, 2016 Author Posted August 21, 2016 No i havent made a reboot after i changed my settings ill do that now. But for dslreports.com im not getting a score for blufferboat or the next score forget whst it is im only getting a score for speed and its a C. Dont no how it is bc i have 150/150 speeds
Slipknot31286sic6 Posted August 21, 2016 Posted August 21, 2016 Make sure since your inter etc is that high turn off deep packet processing. I wouldn't use cod ultimate profile either. Set your home location by yourself. Turn off strict. When you loading game settings for cod all the Servers in your circle radius will be servers. Servers only pop up when bo3 settings are being downloaded aka guy holding guns at main screen. I don't use cc 99/99, PA at zero, miles 300, Port forwarding at 3074 Udp. I play hc tdm. Usually l 4 bar lobby 120k kills 2.3k/d. 367 spm. . Easy way to tell if ur Shit working. Put on vmp or kuda Of ur mowing mofos down in. Using uav/cuav/hatr. . 40 kills in a game 1 assist. That tells me Duma a godsend. . If you getting assists like crazy with msg then something up. . Hope this helps. Duma won't fix every lobby so t judge this on 1 game. Base off like 15. Too many people have high hopes. I don't get perfect lobby everytime and campers ruin it somethings or lots of party lobby. Netduma does not fix a lobby if you see party's galore.
Pwhirl101 Posted August 21, 2016 Author Posted August 21, 2016 Ok one last thing how would i port forward those numbers u said is thst trew duma or fios. Thanks again for your help
Slipknot31286sic6 Posted August 21, 2016 Posted August 21, 2016 Go to netduma os. I left side click settings. Port forward. Just make sure you put in correct ip for ur ps4 and it says Udp. Not tcp
Pwhirl101 Posted August 21, 2016 Author Posted August 21, 2016 Cool thank you ill let u know how it works
Netduma Staff Netduma Crossy Posted August 21, 2016 Netduma Staff Posted August 21, 2016 Yes im using cod ultimate That's why your home location was moving to the ocean then. This is intended and is how the profile helps you find low latency games. I'd definitely suggest using congestion control at 70% each way to ensure there is no local congestion. You could also try some of the different CoD profiles and see how they play.
Administrators Netduma Fraser Posted August 22, 2016 Administrators Posted August 22, 2016 Let us know how you get on as I'll have some differing advice
Pwhirl101 Posted August 22, 2016 Author Posted August 22, 2016 Yea i changed the cod ultimate moved my location takes a little to get in a game but does not run as smoothly as im hearing other people say. Not sure i have all my settings correct? What other advice do u have fraser. And again thanks for helping me out
Administrators Netduma Fraser Posted August 23, 2016 Administrators Posted August 23, 2016 Make sure ALL devices are connected to the R1. 70/70 anti-flood Console in hyper traffic ~1000km radius around your home Strict on PA 0 to start Auto&bleeding edge cloud ticked and applied See how you get on with that.
Pwhirl101 Posted August 23, 2016 Author Posted August 23, 2016 Ok ill set that up. Last question i know everything has to be connected to r1. I have T-Mobile phone service but i dont get phone service in my house so i got a signal booster but it dont work when i connect it to r1 but it works when connected to fios. (Its hard wired theres no wifi) is there something I need to change in setting for thst to work. If not having it hooked up to fios gonna cause problems with r1?
Administrators Netduma Fraser Posted August 24, 2016 Administrators Posted August 24, 2016 Ok ill set that up. Last question i know everything has to be connected to r1. I have T-Mobile phone service but i dont get phone service in my house so i got a signal booster but it dont work when i connect it to r1 but it works when connected to fios. (Its hard wired theres no wifi) is there something I need to change in setting for thst to work. If not having it hooked up to fios gonna cause problems with r1? Two thoughts, turn off turbo mode if you have it enabled. Does it work then? Turn reactive to preemptive, does it work then? I shouldn't think it would cause too many issues being connected to fios.
