gustins32 Posted August 13, 2016 Posted August 13, 2016 Hello guys i was trying to pick up one of netsuma r1 setting options,( congestion control, host filtering ect...) but it's dosen't load up, if it's dos, then it takes really long time, any suggestions, If it's load up i can use it, but other way i just seen loading bars, on screen. And i was trying to use imac, or iphone or windows laptop, it's dosen't make any difference, Please help. Thanks in advance.
Zennon Posted August 13, 2016 Posted August 13, 2016 When you are in the GUI make sure you have the standard theme selected in misc settings Try cookies enabled and disabled to see if there is a change. Press reboot from misc settings. If non of the above work turn off the Netduma for 5 minutes and try again.
gustins32 Posted August 13, 2016 Author Posted August 13, 2016 Cheers Zennon, did work out with cookies,
Administrators Netduma Fraser Posted August 15, 2016 Administrators Posted August 15, 2016 Cookies is best enabled to save your settings.
