Need Help With Configuring Netduma GamePlay is Unreliable @ netduma
K1dN0P1AY
Hello I bought my netduma about a month ago and I really like the ideas behind it but since I had it I haven't notice a difference in gameplay at all I mostly play bo3. I wouldnt consider myself a noob either before the third patch I was dropping gameplay of 70 kills and above but after patch 3 the lag became unbearable. So I purchased the netduma I've read forums,I've watched YouTube videos and I see everybody's netduma is working to perfection but mine please help. I'm paying for 150 Mbps download and 10 upload my setup is modem then netduma @netduma
That's what I usually do but it doesnt work and have you had better experiences with other games
@tryhardundies
You get stupid answers. tryhardundies????
First of all:
Set up your bandwith. Set up your console in host filtering.
Afther that check http://www.dslreports.com/speedtest
Check it on preemptive and reactive with sliders on 100%
If you checked that turn sliders on CC 10-10 then go to: http://www.dslreports.com/speedtestagain.
check it on reactive and preemptive.
For me CC10-10 on preemptive is cool. I run 150-15 up/down.
Make sure IPV6 is unclicked on LAN-WAN at misscalanous. And make sure VPN is off.
Say if it improves. On dsl check diffrent CC settings to get A+-A and ? because speed is irrelevant.
And on Geo choose servers neirby...
It is possible to get there but not if you follow some guys on the forum.....
Come back to me PM or PM I am Mod Box.. he is cool too
Clear?
  • 2 weeks later...
First of all:
Clear?
Stupid answers? Everything you said there would have been done with auto set-up once he'd entered his bandwidth.
Like I said BO3 isn't a very stable game connection wise, I've had much better experiences using the Netduma with other CoDs, particularly Infinity Ward versions e.g. Ghosts (see examples on my YT channel).
If you enter your upload/download figures & then click auto set-up the Netduma will do the rest.
For Congestion Control, I personally use the recommended 70 / 70.
In terms of the Geofilter, try using one of the default CoD Profiles.
Best keeping things simple & use default / auto set-up wherever possible.
