cycotic101 Posted April 9, 2016 Share Posted April 9, 2016 Hello everyone, Just got my netduma today and plugged everything up. Got the to the control panel screen and went down to settings to set a static ip and then it kicked me out of the control panel and says I have no internet connection. Tried resetting everything and no luck. Cannot access anything while I'm connected to the netduma not even the control panel with the 192.168.88.1 Link to comment Share on other sites More sharing options...
3zo000oz Posted April 9, 2016 Share Posted April 9, 2016 Try resseting the router with small stick Link to comment Share on other sites More sharing options...
Comannche Posted April 9, 2016 Share Posted April 9, 2016 Are you connecting via WiFi or cable to the Netduma? If your using WiFi try with a cable. Link to comment Share on other sites More sharing options...
cycotic101 Posted April 9, 2016 Author Share Posted April 9, 2016 Can't use wifi, seems the password has changed when I reset it and when I use cord it just displays "No Internet Access" and does not let me access the Netduma control panel Link to comment Share on other sites More sharing options...
cycotic101 Posted April 9, 2016 Author Share Posted April 9, 2016 Thanks in advance for your help. Link to comment Share on other sites More sharing options...
iAmMoDBoX Posted April 10, 2016 Share Posted April 10, 2016 Can't use wifi, seems the password has changed when I reset it and when I use cord it just displays "No Internet Access" and does not let me access the Netduma control panel When you reset, the password changes to netdumar1 Link to comment Share on other sites More sharing options...
cycotic101 Posted April 10, 2016 Author Share Posted April 10, 2016 When you reset, the password changes to netdumar1 Didn't work for me =( Link to comment Share on other sites More sharing options...
cycotic101 Posted April 10, 2016 Author Share Posted April 10, 2016 Gave "netdumar1" a try and still couldn't access through wifi Link to comment Share on other sites More sharing options...
cycotic101 Posted April 11, 2016 Author Share Posted April 11, 2016 How do you get help from an admin? Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted April 11, 2016 Administrators Share Posted April 11, 2016 Can you follow this guide please http://wiki.netduma.com/doku.php?id=unbrick_routerand see if you are able to access the interface. If so, change back the settings you changed originally. Link to comment Share on other sites More sharing options...
cycotic101 Posted April 11, 2016 Author Share Posted April 11, 2016 Can you follow this guide please http://wiki.netduma.com/doku.php?id=unbrick_routerand see if you are able to access the interface. If so, change back the settings you changed originally. I tried this and could not acces the interface with 192.168.1.1 or 192.168.88.1 or http://r1 Link to comment Share on other sites More sharing options...
Netduma Staff Netduma Crossy Posted April 11, 2016 Netduma Staff Share Posted April 11, 2016 Where you setting up a static IP for a device connected to the Netduma or for the Netduma its self? Link to comment Share on other sites More sharing options...
cycotic101 Posted April 11, 2016 Author Share Posted April 11, 2016 Where you setting up a static IP for a device connected to the Netduma or for the Netduma its self? The netduma itself but I didn't get the chance to press apply because the interface froze so I reset it with the button on the back and since then been locked out Link to comment Share on other sites More sharing options...
Netduma Staff Netduma Crossy Posted April 11, 2016 Netduma Staff Share Posted April 11, 2016 Ok. When you access it through Ethernet do you get an internet connection? Also ensure that port 1 is been used to connect to your modem then one of the other ports is what you're connecting your computer to. Link to comment Share on other sites More sharing options...
cycotic101 Posted April 11, 2016 Author Share Posted April 11, 2016 Ok. When you access it through Ethernet do you get an internet connection? Also ensure that port 1 is been used to connect to your modem then one of the other ports is what you're connecting your computer to. Not getting any internet from netduma. Connected straight to isp hub and I did get a internet connection Link to comment Share on other sites More sharing options...
Netduma Staff Netduma Crossy Posted April 11, 2016 Netduma Staff Share Posted April 11, 2016 Not getting any internet from netduma. Connected straight to isp hub and I did get a internet connection Do you get assigned an IP from the Netduma when you connect via Ethernet? Link to comment Share on other sites More sharing options...
cycotic101 Posted April 11, 2016 Author Share Posted April 11, 2016 Do you get assigned an IP from the Netduma when you connect via Ethernet? No I don't. And when I ipconfig while the Ethernet is connected the Gateway is also Blank Link to comment Share on other sites More sharing options...
Netduma Staff Netduma Crossy Posted April 11, 2016 Netduma Staff Share Posted April 11, 2016 Ok. Could you try configuring a static IP on your PC and see if you can connect to the Duma then. Maybe for some reason DHCP has been disabled on the Netduma. Link to comment Share on other sites More sharing options...
cycotic101 Posted April 11, 2016 Author Share Posted April 11, 2016 Ok. Could you try configuring a static IP on your PC and see if you can connect to the Duma then. Maybe for some reason DHCP has been disabled on the Netduma. I'll give it a go on my lunch in about 30 min and let you know, and thank you for the quick replies. Link to comment Share on other sites More sharing options...
cycotic101 Posted April 11, 2016 Author Share Posted April 11, 2016 Ok. Could you try configuring a static IP on your PC and see if you can connect to the Duma then. Maybe for some reason DHCP has been disabled on the Netduma. Still didn't work =( Link to comment Share on other sites More sharing options...
cycotic101 Posted April 12, 2016 Author Share Posted April 12, 2016 Ok. Could you try configuring a static IP on your PC and see if you can connect to the Duma then. Maybe for some reason DHCP has been disabled on the Netduma. Any other Suggestions? Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted April 12, 2016 Administrators Share Posted April 12, 2016 We'll do our 1 on 1 and go from there Link to comment Share on other sites More sharing options...
cycotic101 Posted April 12, 2016 Author Share Posted April 12, 2016 We'll do our 1 on 1 and go from there Perfect, thank you Link to comment Share on other sites More sharing options...
Crashoverride Posted June 28, 2016 Share Posted June 28, 2016 Did this ever get resolved?????? This is what's happening to my netduma. Link to comment Share on other sites More sharing options...
cycotic101 Posted June 28, 2016 Author Share Posted June 28, 2016 Did this ever get resolved?????? This is what's happening to my netduma. They went ahead and replaced mine after the 1 on 1. Are you trying to access your control panel using Ethernet cable? if not give it a try and let me know I'll try to give your the same advice they gave me when they help me. And do you get a Wifi Signal from the Netduma? Link to comment Share on other sites More sharing options...
