cmikel Posted February 20, 2016 Posted February 20, 2016 hello. i have read the wiki on how to fix slow speeds and while that has helped greatly, it has not fixed the problem. before netduma - i had a linksys ac3200. when running speed tests wirelessly - i would get ~200 down. now with netduma sitting in the same location, using the same speed test site - i get ~100 down. my settings on netduma related to speed are as follows: reactive algorithm caps are 100% turbo mode - selected deep packet - unselected all ipv6 disabled any additional help or steps to get me closer to my original wifi speeds would be appreciated.
Zennon Posted February 20, 2016 Posted February 20, 2016 The linksys has AC Wifi this is why there is a drop in Wifi speeds can you put the linksys in AP mode ? If so modem > netduma (wifi off) > linksys ap mode (wifi on)
cmikel Posted February 20, 2016 Author Posted February 20, 2016 wow - this works! thank you! question - my router knowledge is only so-so, but i assume what is happening is i have all the power of the netduma for geo-filter for gaming, etc but using my router to broadcast a better signal? please correct me if i am wrong on this assumption.
Zennon Posted February 20, 2016 Posted February 20, 2016 Yes that is correct cmikel As this has fixed your issue I will closed the thread if you have any other question's please start a new thread.
