scooby Posted February 17, 2016 Posted February 17, 2016 I have had wifi disabled on my duma but wish to enable it....but keeps coming up incorrect channel value..what am i doing wrong
Zennon Posted February 17, 2016 Posted February 17, 2016 Channel 14 is unavailable in the UK and only up to channel 11 in the US. I am not sure if this is your issue?
scooby Posted February 17, 2016 Author Posted February 17, 2016 when i go to select a channel...7 say i click on it but it doesnt appear in the box
Zennon Posted February 17, 2016 Posted February 17, 2016 Try a reboot from misc settings. If that does not work do a hard boot , turn off for 5 min's then reboot the duma.
scooby Posted February 17, 2016 Author Posted February 17, 2016 did a reboot before i posted... will do the hard boot and let you know thanks
Zennon Posted February 17, 2016 Posted February 17, 2016 Change the security to WPA2-PSK and try again.
scooby Posted February 17, 2016 Author Posted February 17, 2016 thats what i use..already tried all 3 variations...when i select the channel number..any..the channel number box does not show the number
Zennon Posted February 17, 2016 Posted February 17, 2016 Is the WiFi broadcasting even though it does not display a number?
scooby Posted February 17, 2016 Author Posted February 17, 2016 no wifi network being broadcast because it wont enable..just keeps coming up with incorrect channel value
Zennon Posted February 17, 2016 Posted February 17, 2016 Have you tried turning the WiFi off and back on again? Ok after everything I have suggested and that has not worked I think Fraser needs to take a look at this.
scooby Posted February 17, 2016 Author Posted February 17, 2016 think i will try a factory reset...will it harm the router..and will i have to download the latest firmware again
Zennon Posted February 17, 2016 Posted February 17, 2016 Do it from the misc settings page, you will lose all your settings though. You could save a profile.
Administrators Netduma Fraser Posted February 18, 2016 Administrators Posted February 18, 2016 think i will try a factory reset...will it harm the router..and will i have to download the latest firmware again You'll lose settings. Won't harm the router and you won't need to download latest firmware. If this doesn't work try selecting a channel using the keyboard (Up + down and enter to select) see if that works
