why is my Download speed is way down with my NETDUMA?
Thanks for the tip, its normal now when i moved it to 100%. is my download speed normal even when the test shows less? Why would you want it set at less than 100%?
When you lower it, it does lower your speeds but lowering to less than 100 means you will eliminate any local congestion.
And by local congestion Fraser is talking about others in your home using the net at the same time as you are trying to game.
Any speed tests set sliders to 100 percent,while gaming move them to 70 percent to start and tweak from there depending on what's going on in your house with your network.
