DaTz Posted February 4, 2016 Posted February 4, 2016 https://i.imgur.com/nPM6ikD.png very annoying in snd :|
Asentrix Posted February 4, 2016 Posted February 4, 2016 Can you go ahead and read the thread in my signature?It may fix your problem , thanks
e38BimmerFN Posted February 4, 2016 Posted February 4, 2016 How is the R1 connected to the ISP service? What ISP Mfr and model modem do you have? Be sure your Xbox is connected to the R1 via Wired LAN cable. Not wireless.
Administrators Netduma Fraser Posted February 4, 2016 Administrators Posted February 4, 2016 Are you using congestion control? Have you moved your home to try and get a different host?
