Bodeen24 Posted January 5, 2016 Posted January 5, 2016 I have a friend on Black Ops 3 that can not join me who is in New York. He is CLEARLY inside my Geo range and I see him pop up on the map when he tries to join but the yellow triangle comes up everytime. When friends of mine who are outside the Geo range try, I just adjust the range and they are in. In his case, he is already in the range, so what can I do to allow him to join when I host? Thanks
PharmDawgg Posted January 5, 2016 Posted January 5, 2016 Place your fiend on your allow list and that should let him join. http://wiki.netduma.com/doku.php?id=adding_friends_to_your_allow_list If this don't work you may need to disable your Geofilter and then let him join then re-enable it. Lastly if all else fails see if you can't get his ID and get it to Fraser and may he can determine why your friend can't join.
bagsta69 Posted January 5, 2016 Posted January 5, 2016 Sometimes an ip address may be dynamic and an isp will dish out a new ip address if a router is rebooted or turned off and on again. You may simply need to disable the filter and invite again and give 100% in the white list and click on update. then you should be able to join up. Other things to consider on Black ops 3 is Nat type, Do you both have open nat in game and / or Nat type 2 on PS4 or Xbox equivalent.
Administrators Netduma Fraser Posted January 5, 2016 Administrators Posted January 5, 2016 I'd reiterate what the guys have said here, allowing your friend should resolve this. Strange that it is getting blocked though when its in your radius
willywonka Posted January 6, 2016 Posted January 6, 2016 I have the same issue with a guy I play with daily in Texas. He falls within my geofilter range and I had to add him to the filter then all of the sudden he couldn't join my lobby nor I his regardless of filter disabled or enabled.
Administrators Netduma Fraser Posted January 6, 2016 Administrators Posted January 6, 2016 Please PM me guys and ill take a look
willywonka Posted January 6, 2016 Posted January 6, 2016 Please PM me guys and ill take a look I reset everyone in my filter allow list and he could join. Thanks
