​So I wanted to know if I buy the NetDuma am I going to need to get a modem? And if I do will I need a internet service provider or will it come with one?
Thanks for Reading.
Btw I will probably be asking more questions and I'm doing that cause I don't know much and if you could help I would appreciate that.
Hi,
If you have a router already you can use that as your modem. You will need to go into your routers user interface and switch it to modem mode. Then connect the Duma to the router/modem.
