DamoUK Posted December 10, 2015 Posted December 10, 2015 hi ppl, just gotmy netduma (buzzing) but strugglingto set it up , all wired up right and dmz done and xbox works though it but geo just wont filter it , its although its bypassing it no severs show or anything ...something or nothing ? please help ! thx
Netduma Staff Netduma Crossy Posted December 10, 2015 Netduma Staff Posted December 10, 2015 Hey Damo, welcome to the forum Can you make sure that you are on then latest version, using Google Chrome and that you've definitely added the right device to the GeoFilter (and got 'Show Hosts' ticked underneath it)
Administrators Netduma Fraser Posted December 10, 2015 Administrators Posted December 10, 2015 As well as the above double check everything from here http://wiki.netduma.com/doku.php?id=why_can_t_i_see_anything_on_the_geofilter
DamoUK Posted December 10, 2015 Author Posted December 10, 2015 cheers guys thanks for the advice , done all of the above any still no joy ... map is showing hosts (red) and many padlocks ? and xbox is working and finding matches bo3 but it seems asthough it is bypassing the filter .....any adive welcome ...
