Xacebop Posted December 1, 2015 Share Posted December 1, 2015 Nat is open for both, wireless speeds are decent 5mbps down 1.5 up. Wired is .5 down 2 up. I've checked the power line and my laptop is getting 20mbps down through the same Ethernet line. The only thing I can think of would be an issue with the MAC address? I've reset it and it didn't help, this makes no sense. Link to comment Share on other sites More sharing options...
Netduma Staff Netduma Crossy Posted December 1, 2015 Netduma Staff Share Posted December 1, 2015 It might just be in-accurasies in the test. You could try using the browser to do a HTML 5 speed check instead of using the Xbox one. Link to comment Share on other sites More sharing options...
Xacebop Posted December 1, 2015 Author Share Posted December 1, 2015 It's not that, It won't load Netflix or anything Link to comment Share on other sites More sharing options...
Netduma Staff Netduma Crossy Posted December 1, 2015 Netduma Staff Share Posted December 1, 2015 It's not that, It won't load Netflix or anything Have you done any device prioritisation? If you have can you try pressing 'Reset Distribution' and see if that fixes anything Link to comment Share on other sites More sharing options...
Xacebop Posted December 1, 2015 Author Share Posted December 1, 2015 Tried it, and as I said over wifi it has no problems, I'm thinking its Xbox related and not netduma but I have no idea why it works fine wirelessly Link to comment Share on other sites More sharing options...
Netduma Staff Netduma Crossy Posted December 1, 2015 Netduma Staff Share Posted December 1, 2015 Tried it, and as I said over wifi it has no problems, I'm thinking its Xbox related and not netduma but I have no idea why it works fine wirelessly Maybe it is an Xbox problem. The Xbox speedtest isn't too reliable so it could be related to that. Link to comment Share on other sites More sharing options...
Administrators Netduma Fraser Posted December 2, 2015 Administrators Share Posted December 2, 2015 Just to add is your ethernet connection set up using automatic settings? Link to comment Share on other sites More sharing options...
Xacebop Posted December 2, 2015 Author Share Posted December 2, 2015 Yeah I've tried auto and manual settings. I've tried google dns, my router dns and auto dns nothing's effecting the speed. The same adapter in the same outlet gives my ps4 great speeds. I'm wondering if it's because I'm in the preview program for Xbox or it may be my MAC address I don't know though if it was the netduma id be having the same problem over wifi but wifi works just fine. Link to comment Share on other sites More sharing options...
