blankplanet Posted November 22, 2015 Posted November 22, 2015 Today I've had problems connecting a laptop to the Netduma wifi. It will show as an available network but will not connect; I've tried numerous restarts and factory resets. I did have this issue early on and a reset resolved it but it hasn't this time. What else can I do? My setup is - BT hub > R1. The hub still has wireless switched on for home use, mostly just for emails. Wireless settings are channel 7 at 2.4ghz Thanks
Netduma Staff Netduma Crossy Posted November 22, 2015 Netduma Staff Posted November 22, 2015 Hi, Do you get an error message at all when connecting? Also try unsticking Wifi Workaround in Settings >> Miscellaneous
blankplanet Posted November 22, 2015 Author Posted November 22, 2015 All I get is a message that Windows cannot connect to Netduma R1. I have unchecked wifi workaround and nothing's changed.
Netduma Staff Netduma Crossy Posted November 22, 2015 Netduma Staff Posted November 22, 2015 All I get is a message that Windows cannot connect to Netduma R1. I have unchecked wifi workaround and nothing's changed. Are you entering the correct password? Can you try changing the password.
Zennon Posted November 23, 2015 Posted November 23, 2015 Glad to see you have this cleared up, I will close the thread.
