Throttling help ps4
Ian88
So I'm reading left right and centre that telling the duma you have significantly lower bandwidth then you actually have helps in bo3.. So.. I have 100MB down and 7up.. Any suggestions where the sweet spot would be? And any other tweaks? This isn't the lowest wins is it? Or I'll just put my upload to less then 1MB? Or is that too low or what? Detailed help would be greatly appreciated thanks
Oh nearly forgot, my wife plays on a second ps4 on bo3.. I never enable hers when we play, do I need to take that into consideration before throttling?
Dont know if you saw but i answered you on the other thread that you posted on, your Upload is the same as mine so try all the settings HERE
Yeah just seen thankyou.. Do you know if that would effect my wife's console that isn't enabled playing with me in the same lobby or will it be OK? Cheers raddy mate
if you host a party and let her join with you running in the Geo-Filter you should both be fine.
Ok great cheers man.. I can't seem to see what you set your bandwidth because I'm on my phone and seem to see the pic.. What have you set ur up and down? Sorry for all the questions lol
Its in my Sig :)
I started with Raddy's set up and tinkered till I got all A's on dsl reports. For me everything bout the same but down is at 70mb
