need help for setting up Host filtering @PS4
Hi iam Suresh,
i brought R1 yesterday..i had updated to latest version ...i tried to set up host filter..when ever i enable my host filter..PS4 is not connecting to internet - (error message is time taking to long to connect)..with host filter disabled PS4 is connecting to internet..
i am from Malaysia..present set up..i had connected R1 to Unifi router
Try settings misc settings, enable auto cloud and bleeding edge cloud and press update, turn back on the geo-filter and try again.
 already auto cloud and bleeding edge are  ticked i once again applyed it and rebooted R1 still unable to connect to host filtering
before posting help almost i have turned every page in yours wiki and applied ever thing that came across...really need help..my purpose of buying Netduma R1 is going to vain..with out host filtering
Could this be that the matchmaking server needs added to the cloud Fraser? Suresh is located in Malaysia.
For now I would start up your game wait until you are added to the server then apply the filter.
tnx now it is working....earlier i after enabling host filter i usually checked..test connection in PS4 and it says failed...after yours advise i just started my game and enabled host filter and it is working fine..tnx for help..
hope this information is updated in yours wiki..
Thats is great if you have any more questions please open a new post thank you :)
