KennethNielsen1996 Posted November 4, 2015 Posted November 4, 2015 Hey, I need some help with the netduma router. i Can't access the Netduma Control Panel. The Website can't be displayed for some reason. - And i followed the Quick Start Guide.
Netduma Staff Netduma Crossy Posted November 4, 2015 Netduma Staff Posted November 4, 2015 Hi Kenneth, welcome to the forum Can you follow this guide and see if it gives you access to the dashboard.
KennethNielsen1996 Posted November 5, 2015 Author Posted November 5, 2015 When i type idconfig while i have the Netduma R1 connected it says, idconfig is not recognized as an internal or external command - And how do i find that WAN stuff? bcz i can't access that 192.168.88.1 site at all...
Tommy885 Posted November 5, 2015 Posted November 5, 2015 Hi there Kenneth, It's "ipconfig" in CMD and make sure your computer in not Plugged into the WAN port on the router (Port 1) i had done that a few times and couldn't connect in. Tom.
KennethNielsen1996 Posted November 5, 2015 Author Posted November 5, 2015 No matter what i do. i Can't get Access to Netduma's Control Panel via PC... :/
Administrators Netduma Fraser Posted November 6, 2015 Administrators Posted November 6, 2015 Can you follow this and see if you can access the interface that way http://wiki.netduma.com/doku.php?id=unbrick_router
