onezerosix141 Posted October 24, 2015 Posted October 24, 2015 so, i'm running: Coax => Netgear CM500 (cable modem) => Netduma to both tests were ran with just my PC running. I do set Device Manager > Internet connection to the speed I get when i'm running without Netduma. how can i fix this? With Netduma Without
Zennon Posted October 24, 2015 Posted October 24, 2015 onezerosix141, try this if you have not already. http://wiki.netduma.com/doku.php?id=why_is_my_speed_lower&s[]= Reset the device priority flower and set to 100% congestion control while you test.
onezerosix141 Posted October 24, 2015 Author Posted October 24, 2015 i'm in love/hate relationship with Netduma. i love the fact i get lots of help from the community/support. i hate the fact that the community/support points out the problem is usually (majority) caused by me >.> thanks Zennon. that worked onezerosix141, try this if you have not already. http://wiki.netduma.com/doku.php?id=why_is_my_speed_lower&s[]= Reset the device priority flower and set to 100% congestion control while you test.
Alex49H Posted October 26, 2015 Posted October 26, 2015 so, i'm running: Coax => Netgear CM500 (cable modem) => Netduma to both tests were ran with just my PC running. I do set Device Manager > Internet connection to the speed I get when i'm running without Netduma. how can i fix this? With Netduma Without How do you like the CM500?
onezerosix141 Posted October 28, 2015 Author Posted October 28, 2015 i like it. it's been playing nice with Netduma. i was using two different models of Surfboad but didn't work as well as CM500.
Zennon Posted October 28, 2015 Posted October 28, 2015 I see this is resolved now, I will closed the thread any more question just ask, thanks
