Mobile connectivity problems.
I've searched the forums and google with no returns on this problem. So if this has been answered i do apologise!
Basically my phone has issues being connected to the Netduma, i've had this issue on old and new firmwares and old and new phones.
(currently the LGG4)
Problem description:
After my phone has been connected to the Duma for a short period, any browsing performed on the phone gets stuck in an endless page loading scenario.
An example would be! Opening a webbrowser and searching in google or clicking a frequent tab, and being stuck on page loading.
Or opening twitter / facebook and getting stuck in endless load cycles.
The only way to break this is to disconnect and reconnect wifi...
This is a problem i have been putting up with since i got the router "early adopter" i keep meaning to report the problem, but then i'm either too lazy to do so, or i get distracted.
It was suggested to me to download Wifi analyzer and select the best channel, i done this, it had no effect.
Such a simple fix, if it works.. Thanks guys..
Can i ask what exactly that setting is supposed to be doing, and the pros/cons of it?
This fixed my problem, thank you. :)
Great to hear that!
Theres an issue with some phones and the rescanning of wifi I believe. So the wifi workaround was implemented to fix that issue.
As this issue has been resolved I'll close the thread, feel free to make another if needed :)
