Bt home hub 4
My friend just got his duma. But we are both struggling to find the modem mode on the bt home hub 4 Could somebody help please
Hi Ian,
I don't think there is a modem bore for the HH4. Instead you can just place the Netduma in the HHs DMZ and it will work fine :)
Exactly as Crossy says, would also recommend disabling the wifi on the home hub so you prevent conflicts with the R1's wifi.
If you can't find the DMZ option its likely in firewall settings
Hello all, i'm having a bit of trouble with the home hub aswell. i'm trying to get my NAT type to open but i cant seem to figure it out any help would be appreciated thanks
Did you follow the guide linked above?
Did you find the DMZ option in the home hub?
Welcome to the forum by the way :)
I made a mistake somewhere, All sorted now thank you   :D Awesome bit of kit by the way! Thanks Fraser  :)
Great news! You should make a post over in introductions so we can all welcome you properly :)
