Installation problems with at&t router/modem
When I plug my Netduma r1 gaming router into my AT&T Arris NVG589 it shows up in my networks as both of them there because my AT&T provided router is a router and a modem in one so i was wondering how i can link both the routers ????
Hello Avtennisman, welcome to the forum :)
If you plug the Arris into port one of the Netduma an then put the Netduma in the Arris's DMZ you should be good to go. Is this what you are having problems with?
I plugged it in now. It shows that I am in Australia; how do I change this to the US? The network is VERY slow now.
Can you look at these settings to move your home location :)
