HRichie Posted October 16 Posted October 16 Hi guys, fairly new here and kinda useless with all this router stuff so please bear with me. My R2 has a habit of disconnecting from the internet, and I realised my firmware is well out of date. However when I try and update to the latest firmware, I just get the usual buffering icon and thats it. I have included the file I believe is the latest update. Any help or advice appreciated. DumaOS-R2-3.3.280.sig
Administrators Netduma Fraser Posted October 17 Administrators Posted October 17 I've given you Early Access which has the latest firmware there https://forum.netduma.com/forum/144-netduma-r2-early-access/ Reboot the router and then upgrade and it should work HRichie 1
HRichie Posted October 19 Author Posted October 19 Thanks Fraser. Will give it a go tomorrow..fingers crossed 👍 Netduma Fraser 1
Administrators Netduma Fraser Posted October 20 Administrators Posted October 20 Let us know how you get on!
HRichie Posted October 21 Author Posted October 21 Hi Fraser. What you suggested hasnt worked. I've been trying thru chat gpt also which suggests me sending you the following: My Netduma R2 is running firmware 3.3.142. Updating to 3.3.280 via Ethernet uploads the file but fails. The interface partially loads and displays “Please try again in a minute.” I increased R-App retries to 5 and rebooted, but the problem persists. DumaOS Updates is not listed under Installed Apps. This also applies with version 258 you suggested
Administrators Netduma Fraser Posted October 22 Administrators Posted October 22 Factory reset and then try to upgrade as quickly as possible and it should work
HRichie Posted October 22 Author Posted October 22 Tried but still the same outcome. The interface partially loads then message "try again in a minute" appears.
Administrators Netduma Fraser Posted October 23 Administrators Posted October 23 Make sure you're trying via ethernet and using a web browser in Incognito mode, connecting via HTTP not HTTPS (some browsers force HTTPS) and if that doesn't work try via the mobile app instead. Do a reboot before each try.
