Maxell Posted October 14 Posted October 14 Is advanced web protect compatible with the wifi optimiser? All I get now for the wifi optimiser is connect to your home wifi network to use WiFi Optimiser. I am already connected. The only difference is that I recently activated advanced web protect.
Administrators Netduma Fraser Posted October 15 Administrators Posted October 15 I think that's more of a question for EE, I would have thought they would have done testing to ensure the different types of products they have work well together. Disable AWP, does optimiser then appear to give you more options? Also disable optimiser then re-enable it to see if that works. Maxell 1
